problems uploading website
sophie1983
Member
Hi,
I have designed a website using Flux, I have tried uploading it through Flux but it couldn't connect to the FTP site, I then tried uploading with a web browser, it connected to the FTP but when it opened the folder it was read only so I couldn't copy any files into it. Any idea what I'm doing wrong?
Any help much appreciated
1 ACCEPTED SOLUTION
Accepted Solutions
BLWRAVE
BT Partner
BT Partner
Hello
   The reason you can not upload content using web browser FTP is because you can only download information not upload. In regards to using Flux, I use Filezilla and user and Host are "your domain" and Password would be your "domain Password" and the Port should be set at 21. These settings should allow you to gain access to you domains FTP
View solution in original post
1 REPLY 1
BLWRAVE
BT Partner
BT Partner
Hello
