website
richardaustin
Member
Hi
I'm sorry if this covers old ground, but I'm new to this forum.
Can anyone tell me the size of the old BTopenworld web hosting site, which I still use and have a website on.This is now causing the message (226 Quota overfolow this caused the file to be deleted), and I assume that I've run out of space.
 If I change to BT Webhosting lite will I still be able to build a site with Netobjects and upload it using this package.
Richardaustin
1 ACCEPTED SOLUTION
Accepted Solutions
spank
Grand Guru
Hi there,
I think the old package was 50mb.  I also think if you are using the old package then you have likely already been migrated to web hosting lite.
You can use netobject with any of the hosting packages yes.
View solution in original post
1 REPLY 1
spank
Grand Guru
Hi there,
