Hi Guys,
I've recently got a BT Infinity business service with 5 static IP's and it came with BT Business Hub 3. I have a cisco 1712 modular router with 4 port switch module installed. I wanted to use this router instead of Business Hub 3. I saw some posts and configured but can't configure ip tcp adjust-mss on the switch module. Can anyone please help me. I also need to set it up for Static ip. I'm pasting the link i got and my config below.
Which cisco router is working best on BT infinity?
http://community.bt.com/t5/BT-Infinity/Infinity-on-Cisco-Router/td-p/149185
interface FastEthernet0
description *** BT-WAN ***
ip address dhcp
ip nat outside
ip virtual-reassembly
ip tcp adjust-mss 1452
shutdown
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no routing dynamic
interface FastEthernet1
switchport access vlan 10
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface Vlan1
no ip address
shutdown
interface Vlan10
description Local
ip address 10.10.10.5 255.255.255.0
ip mtu 1350
ip nat inside
interface Dialer1
ip address negotiated
no ip unreachables
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname [email protected]
ppp chap password 7 120E00002104040401
ppp pap sent-username [email protected] password 7 120E00002104040401
ppp ipcp dns request
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip nat inside source list ACL-LAN interface Dialer1 overload
ip access-list standard ACL-LAN
permit 10.10.10.0 0.0.0.255
access-list 99 permit 217.40.xxx.xxx 0.0.0.7 log
access-list 99 permit 10.10.10.0 0.0.0.255
access-list 99 permit 10.10.0.0 0.0.0.255
Hi
Did you ever get your 1712 working on your BT Infinity? Reason I ask, the BT business hub does not do it for me and I have a spare 1720 with a 4 port switch card in too.
The main ask, how did you get on with using the '5' ip addresses BT have given you and the CISCO router?
Even if you abandoned the CISCO route, what router do you use that works with BT and their implmentation of the '5' ip address service?
Cheers
Crizco
