wifi connection
josspross
Member
I have a BT package with unlimited Broadband but not BTtv.  I have just bought a Sony bravia with a LAN port can I connect wirelessly with my BT home hub or do I have to have a wired up connection and how to both!!!!!!
1 REPLY 1
Ian1974
Moderator
Moderator
Hi Josspross,
You can connect this to our home hub, all you need to do is to connect one of the numbered ports on back of rout (1-4) and connect this to the lan port of your TV.
With regards to the Wireless set up you will need to go into the tv menu and look for the wireless option in there.
Once in the wireless section you should seee your home hubs ID, just select that then eter your wifi password.
Kind Regards,
Ian - F -
BT Business Support
