Member
0
Accepted Solution
Broadband in the Newcastle area
Hi,
Can somebody from BT provide an update on the problems in the Newcastle area, affecting these dialling codes:
01642 01661 019122 019123 019124 019125 019127 019129 & 019123
Quoting from your status page:
"We hope to have your service back to normal within the next 2 hours."
It has now been 22 hours, and nobody at BT seems to be able to provide an update.
Regards,
Robin
gs
Super User
0
Re: Broadband in the Newcastle area
Thats becuase there isnt an update, it will be fixed as soon as possible, only if something serious happens that will take the exchanges out for several weeks will they provide an update. Thats the way it has always been.
You can try complaining, but BT will simply state in that in its T&C's they will attempt to, but cannot guarantee that they can warn you about updates/upgrades/faults.
BT Employee
0
Hi
I have checked with the Broadband Technical team and they have said that the issue should now be resolved and the server status page updated.
If you are still experiencing issues please contact the technical support team.
Kind Regards
Fiona
BT Business Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
