Member
0
Connect drops when multiple devices in use (Fibre BT)
We have Fibre Optic Broadband Business, so normally when multiple devices etc are connected the connection is fine and is no problems but now when Im gaming and if anyone else is watching a video or anything on Wireless it gives me very bad connection drops and ping goes up n down which is never used to do I could be watching videos etc and play at the same time with out an issue which Fibre should do.
What is wrong? Ive tried changing routers, Resetting, Factory resets multiple times but it still happens.
Any help please
Super User
0
Re: Connect drops when multiple devices in use (Fibre BT)
Hey hurleh,
It's hard to tell with wireless, but it sounds like there's potentially interference which is causing those issues. I would recommend repositioning the router or moving equipment that may be causing an electrical interference to see if that improves the stability at all. I'd recommend trying some devices with ethernet cables rather than wireless to see if they experience the same problem - that way, we can establish if it's just a wireless issue or if there's maybe a problem with the line running slow in general.
Thank you, Bobby
Member
0
Ill try but nothing is new or changed its just happened all of a sudden? and its happening whatever device is in use, ill be on a gaming console and it will just be very laggy and ping will go all over the place which it shouldnt.
Member
0
Also there is a computer in the same room that was running wireless that made the lag occur so I tried using ethernet for it and it still happens
Member
0
anyone help?
Super User
0
Hey hurleh,
If the same problem occurs over ethernet devices, you're best reaching out to the technical team on 0800 800 154 and they'll be able to get that line tested for you to see if there's any network faults that may be causing those intermittent connection issues.
Thank you, Bobby
Member
0
Thanks, moving helped me. The problem was in interference
