Power User
0
Accepted Solution
Do i need a ADSL filter really?
hi
my work broadband has nothing else on it apart from a router.
The BT master socket which im using has nothing else attached.
If i take the face place off to get to the test socket, there are no wires attached to the face plate
Do i really still need a micro filter?
(asking as the upgrade to ADSL2+ is really screwing up our internet)
(Router is a draytec vigor 2800)
thanks
Super User
Re: Do i need a ADSL filter really?
[ Edited ]
short answer, no
if however you plan on plugging something into it then yes you will
you will abviously need an cable that converts bt socket to rj11, or an adaptor for your rj11 cable
Power User
0
thanks Rich, i suspected as much
