Member
Hub name change
Does anyone know how I can change my Business Hub name, from displaying BTbusinessHub to a name of my choice.
Many thanks.
BT Employee
Re: Hub name change
Hi
You should be able to log into the Routers Main Page GUI (normally 192.168.1.254), from here you should be able to click on settings -> LAN -> Wireless, from here you should be able to change the network name.
I hope this helps
Kind Regards
Fiona
BT Business Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
