4G assure and Bridge Mode
toomanylogins
Member
We have just moved premises and while I'm waiting for the new line to be sorted out I assumed the modem would continue working using the 4G dongle. However I have checked and it seems that when you have the modem running in bridging mode you cannot connect via 4G.
Can someone confirm if this is correct?
Thanks Paul
4 REPLIES 4
joecity
Member
From what I can see - this seems to be correct.  4g aspire will only work with the BT Hub and for devices connected to the hub.  Which is terrible - I have my home network setup on my own router as most business users do, and wanted BT in bridge mode, with 4g backup working in bridge mode as well.  Found this out after I signed up, which is very dissappointing.
BethM
Administrator
Administrator
Hi toomanylogins
I can confirm that is correct, the 4g assure will work only if set up correctly through a BT Business Hub 5 or BT Business Smart Hub. You can find out more about how to set up 4g assure here.
Beth
^BethM
Joseph691
Member
Thanks Paul
I am facing the samme isuee.
PaulC1
Administrator
Administrator
Hi Joseph691,
The 4G assure won't work when the Business hub is in bridge mode. Also, the 4G assure is designed to only work in BT hubs. Not 3rd party devices.
I hope this helps,
^PaulC1
