Help setting up the 5 Multiple Static IP Addresses
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I am looking for some assistance in setting up the 5 multiple static ip addresses that I have gotten added to my account.
I was provided with the 5 public addresses, the gateway address and the subnet mask.
Ive looked in the Smart Hub Home>Advanced Settings > Static ip But its looking for a router address? and im not sure what value this should be. Any help would be appreciated.
0
Kudos
1 REPLY 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi RyanW
in regards to this one, usually the router IP should auto-generate. If it doesn't however, you would usually be fine putting the the default gateway should you have been provided it. If not, if you contact our team on livechat they should be able to supply you with this.
You can also find a guide here on setting up multiple IPs on the SmartHub.
Regards
Ryan
0
Kudos
