received Complete Wifi Plus...
ren41
Member
I ordered Complete Wifi and have just received Smart Hub 3 and Complete Wifi Plus. I note the 'disc' calls itself an extender which concerns me; we needed to change from the standard BT extenders as some of our devices are unable to switch independently between the hub and the extenders' own network. I understood that Complete Wifi didn't set up a separate  network and I want to be sure of this before I unbox and set up - can anyone confirm this for me, please?
1 REPLY 1
BethM
Administrator
Administrator
Hi ren41
Yes you're right, it doesn't set up a separate network. Your devices will seamlessly switch between the Wi-Fi Discs or hub, depending on which one is going to give you the strongest, fastest wi-fi signal.
^BethM
