Hey all, I have a strange problem with my Gear S3 and Nexus 6P and seems tasker is the only way to fix it! The problem is I use my Gear to answer and make calls, but when I get in my car, car bluetooth wont connect to phone audio since Gear is connected to it, only way is to disable Gear audio connection to make it work.
I was able to make a profile that when I am in car turns off the Gear audio and connect to car. It works fine, problem is when I am not in the car I am not able to make it reconnect to Gear audio.
I created a profile for when not connected to car that should connect to Gear but it doesnt work and I dont know why.
Thanks for your help.
@bruzogiri wrote:Hey all, I have a strange problem with my Gear S3 and Nexus 6P and seems tasker is the only way to fix it! The problem is I use my Gear to answer and make calls, but when I get in my car, car bluetooth wont connect to phone audio since Gear is connected to it, only way is to disable Gear audio connection to make it work.
I was able to make a profile that when I am in car turns off the Gear audio and connect to car. It works fine, problem is when I am not in the car I am not able to make it reconnect to Gear audio. Ball Sports Gear
Hello,
I can see your post I give you some best ways to solve your query please see below and follow inst...
Based on my knowledge, there are some possible solutions to your problem. Here are some of them:
1. Check the Bluetooth settings on your phone and Gear. Make sure that both devices are paired and connected, and that the phone audio option is enabled for the Gear. You can also try to unpair and pair them again, or clear the Bluetooth cache and data on your phone.
2. Use a Bluetooth priority app. You can use an app like Bluetooth Auto Connect or Bluetooth Connect & Play to set the priority of your Bluetooth devices and switch between them automatically. You can configure the app to connect to your car when it detects it, and to your Gear when you leave the car.
3. Use a different tasker profile. You can use a tasker profile that uses the state of your car charger or the proximity sensor to detect when you are in or out of the car, and then turn on or off the Gear audio accordingly. You can also use the Bluetooth Auto Connect plugin for Tasker to make the connection more reliable.
I hope this helps you with your problem. If you have any other questions, feel free to ask me.
Best regard,
CarolHunter1
