Solved! Go to Solution.
Hi Hmcc654
Sorry to hear about that - if that service was added to your account without your knowledge then I would suggest contacting our Billing team on livechat or by calling 0800 800 152 - they can look into this for you. If you are being charged for a service that you shouldn't be, then they can remove it and add whatever credit is appropriate.
Regards
Ryan
Hi Hmcc654
Regards
Ryan
