BTB Smart Hub has numerous vulnerabilies
kelper
Grand Master
Bitdefender Online Scanner says my BTB smart Hub has numerous http vulnerabilities.
Can I do anything?
Is anyone else running Bitdefender?
3 REPLIES 3
kelper
Grand Master
I eliminated most of the vulnerabilities on my BTB Hub just by turning off UPnP!
My Netgear WN2500RP wifi extender allows unencrypted logins but there is no way i can fix that unless I flash new firmware.
PaulC1
Administrator
Administrator
Hi Kelper,
I am guessing the Bitdefender Scanner tests the security of your hub. If this is saying you have vulnerabilities it could be picking up the ports the hub has open by default. We need this so we can send firmware upgrades to hubs. Customers come to us saying they fail security checks, that are required by card machines. This is due to the fact we need ports open to upgrade.
I hope this helps
^PaulC1
kelper
Grand Master
Thanks.  I'll see if I can get any specifics from Bitdefender.
