7-zip doesn't open the archive folder
PeterRussell
Member
I zipped the "My Documents" folder in WindowsXP ( SP 3 ) using the default application (Send To- Zipped folder) and now it won't unzip.
When using the MS app it comes up " The Compressed folder is invalid or corrupted"
I tired WinZip " Cannot open file; it does not appear to be a valid archive"
Tired 7-zip " Cannot open file.... as archive".
Tried doing a virus scan on it but came back clean.
Any suggestions from here?
3 REPLIES 3
erikpersson67
Member
It seems that the zip file was not completed or corrupted. Have you tried ZIP Recovery Toolbox? If not, then have a try. http://www.oemailrecovery.com/zip_recovery.html
erikpersson67
Member
Also I hope this recommendations can help you somehow.
https://community.office365.com/en-us/f/172/t/257436
PeterRussell
Member
Hi, Thank you for your time and great help. I really appreciate your feedback and I am very thankful for your time and support. Solved!
Many thanks.
