Advance template manager
Bustacee79
Member
i downloaded a template site from my management centre, css format or type, ive loaded it to my public dictionary then found out i needed software programs ie macromedia dream weaver, mx 2004, macromedia flash player mx, adobe photoshop 6, namo web editor and frontpage 2003 which i now have, how do i now publish this template when i have used these softwares to edit it as my main site so public can see it as my old site from bt ews pro is still showing, any help please
1 REPLY 1
BLWRAVE
BT Partner
BT Partner
Hi
When you put your information into the Public it should be viewable online.  I have a questions you say in your post you had to download frontpage and dream weaver, both these are website builders did you build it using one or both of them?
