Android phone email settings
Wetpawprints
Member
I had my btconnect email account set up on my phone but now it no longer works. I have tried adding the account again but keep getting the error message "your incoming server does not support SSL. Please modify your incoming servers security type"
POP server: pop.outlook.com
Security type: SSL
Server port: 995
The email address is a sub account and I have noticed that I am also unable to log into btconnect webmail either although I can with the main account. Could this be linked?
Finding this highly infuriating, would appreciate some help.
3 REPLIES 3
Burkem5
Guru
Hi wetpawprints
Lets work this out
First off i need you to go to www.myoffice.bt.com
login with the BT connect email address,  this will give you a welcome to 365 screen and will tell you what your post migration ID is
This is the address you now need to use to login to the webmail at http://login.microsoftonline.com
It is also the username you will need to use to sign in to pop.outlook.com
try using that username with the following settings
Incoming server
Server - pop.outlook.com
port – 995
connection type – ssl
ensure that this is authorised with the full email address and password including the domain [email protected]
Outgoing
Server - smtp.outlook.com
port – 587
connection type – tls
make sure the outgoing server requires authentication and authenticate with the same details as the incoming server
that should now send and recieve
I will note that sending can only be guarenteed on BT provided WIFI
From a post by Adrianc
"Some mobile providers do what's called 'super NAT' where all the phones in a given area are given private IP addresses (e.g. 10.3.2.1) and share a single IP on the mobile company's network. This can cause a problem if someone is 'naughty' - a whole lot of customers can get blocked because they all appear to be using the same IP address."
Wetpawprints
Member
Hi Burkem,
I can log on to my office with the primary email account and can also log onto the webmail with the primary account but I still cannot log onto any of the sub accounts.
I am getting emails for all the accounts on the main office computer but I still need to be able to have access on my mobile as I did previously.
I have also tried adding the primary account to my mobile but I get the same SSL error message. The Server setting I have been trying are same as you stated.
Burkem5
Guru
can you go to www.myoffice.bt.com > My Services
Login with the Primary account and then go to email summary
this will show you the migrated logins of your accounts and allow you to reset passwords etc should it be needed.
Here is the set up i did for my android tablet.  I realise this is not the same but may give an idea of how to do this.
