Assign Multiple Public IP to Single Firewall
RGo1234
Member
Hi,
I have a BT Business Hub 5 and currently have 5 Public IP's.
I have a Hardware firewall - which I have assigned 1 of the static IP's to.
IS there any way I can assign more than 1 IP to a single device? I would like to have things controlled from my firewall rather than from the BT Hub.
Any assistance would be greatly appreciated.
Thanks,
Rgo
2 REPLIES 2
Plumly
Grand Master
if you only have one network card on the firewall then no,
but going by the sound of it instead of having the router assign the Ips to a device you want the firewall to do this, so if you set the firewall to manage the DHCP and turn DHCP off your hub5 this should fix the issue,
spank
Grand Guru
Hi there,
If your firewall has vlan support then try creating a vlan for each static and assign them all to the same port.
Never done it but seems logical.
