BLANK posts
MHC
Guru
Why do some posts appear totally blank?    There is no text in the body.
3 REPLIES 3
JohnE
Guru
This is likely to do with using Internet Explorer 9.  You will need to enable Compatibility View, please see this:
Some Web sites may not behave as expected in Internet Explorer
MHC
Guru
As I don't have IE9 installed only IE8 which is very rarely used that is unlikely to be the issue.
I use FF - currently 3.6.16 and the problem has only become apparent in te past two or three weeks in which time I have NOT updated FF.
JohnE
Guru
This message was posted using Mozilla Firefox version: 3.6.16
This certainly looks like a browser issue, possibly to do with scripting.  Also, Internet explorer 8 may also require "Compatibility View" to be enabled in order for all forum features to work, although I will admit, actually displaying your post would be pretty basic.
