BT Business Hub 2700G with Windows Server 2003 DHCP - wireless?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi, we're a small charity with a computer network using Windows Server 2003 and a BT 2700 Business Hub. We've had problems with name resolution on our private network, so recently I re-organised as follows:
Disabled DHCP on the business hub
Enabled and set up DHCP on Windows Server 2003.
Set the Windows Server to use the hub as the gateway.
This works in our wired network.
What I don't understand is the wireless access. The BT Hub gives out wireless addresses in 192.178 subnet, which is different from our private network (which is on 169.254 for historical reasons!).
In the original setup, the wireless access point have access to the internet. Now wireless devices can't connect, presumably because the 2700 is no longer in charge of DHCP. I'm not sure what I should do to get things to work again, short of reverting to using router for DHCP.
I might be able to set up another DHCP zone on the Windows server.
I also don't understand where the address range (192.178) for wireless routing is set in the 2700.
Any ideas?
regards
Alan
Southampton Hospital Broadcasting Association
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It sounds like you are connecting to the fusion network instead of the wireless network. In view avaliable networks you should have a wireless connection that is called BT Business hub xxx. The xxx will be the last 3 digits of the serial number of the business hub. This is the one you should be connecting too.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Helpinghands,
no, it doesn't matter whether you use "fusion" or "wireless". In fact I got the subnet wrong in my original post, it's 192.168.178. But that's still different from the subnet we allocated on the wired lan side.
I guess when the 2700 is running dhcp itself, it somehow creates a route from one subnet to the other.
If you look in "static routes" on the 2700, there are lines like this:
169.254.61,1 255.255.255.255 169.254.61.1 bridge0
192.168.178.254 255.255.255.255 192.168.178.254 bridge4
169.254.61,0 255.255.255.255 169.254.61.1 bridge0
192.168.178.0 255.255.255.255 192.168.178.254 bridge4
which I guess is how the two subnets get linked. So I guess if I set up a new zone in the Windows 2003 server for 192.168.178, and assuming dhcp requests get routed to the server, it may work?
regards
Alan
