A few months ago my old Business Hub (2700HGV) gave up the ghost and I now have a shiny new Business Hub 3. For all tasks except Skype it seems perfect, but Skype calls are terrible; while I can hear the other end of the conversation fine, my voice is choppy and drops words. This makes it impossible to use as I conduct a lot of business via skype.
It's not a line issue, as at this moment I have an old Home Hub (the original white one) plugged in and the Skype Test call worked fine on that, whereas it didn't on the Business Hub 3. I can't stick with this Home Hub though as a) it's not mine, and b) stability is an issue; it exhibits the same symptoms as my dead hub, which is poor web access - pages don't load, or only load partially.
Does anyone know if there's something that can be done to the Business Hub to correct the Skype issue, or is buying a new better quality router the only solution?
For completenes, my settings are:
| Connection Information
| ADSL Settings
This is after having just plugged this router back in.
