HI Folks,
The problem I have is that only one laptop can connect to the internet wirelessly. We have 4 laptops that can all see the router and connect to it no problem but there is no gateway to the internet.
The one laptop that can connect has to perform a factory reset of the router before it connects. If i move out of the wireless zone or shut the laptop down I have to factory reset the router again to be able to connect to the internet.
I have rung Bt and they have checked the line and said everything is ok, the guy then said it was my fault as I had given the router a factory reset. The router is 6 months old.
Does any one have any ideas?
Cheers
Solved! Go to Solution.
Ah the joys of technology. One problem, 628.3 possible solutions.
Glad you got it working though.
Dave A
