BT Business Hub - Vodafone Sure Signal won't connet
PeterBanks
Member
I upgraded to Infinity and have a new Business Hub 3. I need to connect a Vodafone Sure Signal to this hub for mobile signal and whilst the VSS goes through the automatic connection set-up, it fails.
The VSS worked on a Sagem router on Sky broadband without issue.
VSS forum suggests router settings may need to be changed
Anyone experienced this before and know how to overcome the problem please?
1 REPLY 1
PeterBanks
Member
Infor for anyone else trying to connect a VSS. Having reset the VSS numerous times and always resulting in fault condition, doing nothing different today the VSS connected! VSS forum had a couple of posts that suggested it might eventually sort itself out and it has done just that. No settings changed in the router, just repeated the vss set-up procedure and reset it each time it failed. Seems there is a bit of black art somewhere with getting the devices working together.
