BT Business Hub extend range ethernet/DC to WIFI AP
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You could possibly increase the output power of the hub but I think the change will only be minimal.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Get an unused Business Hub off ebay ! Whilst using the power plugs to connect the two will work, my preference would be to run an ethernet connection with Cat5e from te original router to te one to be used as an AP - you can easily do 100m withoiut issue. Instructions on converting a 2700 Hub to an AP are in a "sticky" above.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for the reply. Just to be sure I'm using BT 2700HGV as the main router.
So it has the functionality to allow an AP to be configured to it (IF it is another BT Hub and connected via ethernet??? )
Am I correct to assume there are config options to enable this setup within the webpage settings of my BT HUB???
Could you recommend a specific cheap BT HUB model i cna buy that will be do the job??
I think I'm making sense of this.
Thank you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes, use the existing 2700 as the modem and interface to the DSL line exactly as you are now. Then follow the instructions in:
to connect another 2700 to teh existing. You can also use other routers but I cannot advise which or how to set them up.
At times I have had 5 additional 2700s running off the primary.
Just go onto ebay and search for 2700HGV - but find a New or BNIB one - typically £10 to £20 each or you may even get one cheaper.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
That looks OK ... just email and ask for the serial number or at least the first 8 digits and then let me know what it is. Just to check the age/firmware.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hiya guys, im here now trynig to set it up and need some help subnetting.
The IP of original router is 192.168.1.254
what do i subnet the 2nd 2700 IP as??????? Also what should the mask be??
If you can help please do as im here now and starting to crack under the pressure.
thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Serial number of 2nd 2700 is: 990711029683R
