BT Business Poor Browsing Experience
Potter911
Member
Hi there, switched to BT business in June 2010 as we moved house and our old provider could not provide us with broadband at our new house.  We were sent a BT2700HGV business hub with VoIP functionality which we need for our business phone line.
All works fine (VoIP), but we have a poor browsing experience, by which I mean websites loading very slowly or not at all, at seemingly random times. Even though downloading large files (games from Steam) is as should be, and speed testers show good download / upload speeds. These problems happen regardless of whether we are using 3 or 4 computers online at once, or whether we use just 1. Hardwired or wireless, seems to make no difference.
The only thing that does solve this problem is using my old wireless router, a Zoom X6.  This router works perfectly regardless of how many machines are online at one time. The only problem is that it does not have VoIP functionality which we need for the business phone. If it did, we would simply ditch the 2700HGV and use the Zoom X6.
Either way, this leads me to believe it is a problem with the BT2700HGV.
This is what the Broadband status page looks like if anybody was interested.
Down Up
Modem Type:Built in modem - ADSL
DSL Line (Wire Pair):Line 1 (inner pair)
Current DSL Connection:
Rate:7488 kbs448 kbs
Max Rate:7488 kbs1072 kbs
Noise Margin:6.0 dB24.0 dB
Attenuation:27.1 dB14.5 dB
Output Power:19.8 dBm12.2 dBm
Protocol:G.DMT Annex A
Channel:Interleaved
DSLAM Vendor InformationCountry: {46336} Vendor: {TSTC} Specific: {0 }
ATM PVC:0/38
Rate Cap:7488 kbs
Attenuation @ 300kHz:27.1 dB
Uncanceled Echo:-17.4 dBOk
VCXO Frequency Offset:-0.3 ppmOk
Final Receive Gain:11.8 dBOk
Impulse Noise Comp. Tones:0Ok
Excessive Impulse Noise:0Ok
Bytes Packets Errors % Cells Errors %
IP Traffic
Transmit:195994939263616100
Receive:-1585469099489483100
ATM Traffic
Transmit:660316200
Receive:14944001300
Reset 24-hr int. 15-min int. Last Event
 SinceCurrentCurrentTime Since
ATM
Last Event
Cell Header Errors165015:01:51
Loss of cell Delineation4001Day0:55:08
DSL
Link Retrains:0000:00:00
DSL Training Errors:0000:00:00
Training Timeouts:0000:00:00
Loss of Framing Failures:0000:00:00
Loss of Signal Failures:0000:00:00
Loss of Power Failures:0000:00:00
Loss of Margin Failures:0000:00:00
**bleep**. Seconds w/Errors:9402:56:58
**bleep**. Sec. w/Severe Errors:0000:00:00
Corrected Blocks:25111900:16:32
Uncorrectable Blocks:15602:56:58
DSL Unavailable Seconds:33001Day22:02:30
If anyone can help, I would be most grateful.  We've been experiencing this problem since we were using the 2700HGV and tried to ignore the problem, but it is getting rather annoying now.
Many thanks.
1 ACCEPTED SOLUTION
Accepted Solutions
Potter911
Member
Hi guys, looks like the problem is solved!
I did as damian suggested and contacted tech support via live chat, they took control of my computer and changed the DNS in my network adaptors ipv4 settings as follows;
Preferred DNS server: 8.8.8.8
Secondary DNS server: 8.8.4.4
I applied these settings to all the computers on the network and this seems to have fixed the problem! Thanks for your input, and thanks particularly to damian.
View solution in original post
5 REPLIES 5
damian
Member
Hi There - I had exactly the same issue. Same modem and same symptoms.
I was the same an ignored it for a while - yesterday i went onto the Live chat and explained the issue to BT. They took control of my computer remotely and changed my DNS settings. This rectified the issue immediately.
If you mention the issue with DNS above it should save you from explaining the whole problem to them.
Hope this helps!
Fiona
Grand Guru
Hi
Thanks Damian that is really helpful, and i'm really glad the live chat team were able to help you.
Anyone who would like to talk to Technical can do so through Technical Contact Us
Kind Regards
Fiona
BT Business Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
Potter911
Member
Thank you damian, I will have a go with the live chat when I get the chance.
Thanks for posting, I really appreciate it!
philhoward
Member
I am experiencing the same problems as well. Please can you advise the DNS addresses that BT gave you.
Did they alter the DNS settings on your BT2700 HGV router or the ones on your PC?
Hopefully if I can make these alterations it will solve my problems as well.
Many thanks
Phil
Potter911
Member
