BT Business Smart Hub 6 - fix the IP address
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi
Please could someone help ... it seems such a simple thing.
I want to set the LAN (internal) IP address of the hub to be 81.137.109.54
But i will not save the changes .... I've turned off the DHCP (edited the range of valid IPs, even tho it is off!) ....
Please help!
thanks
Rob
0
Kudos
1 REPLY 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there robdarby,
it looks like you are wanting to set the internal LAN IP of the router to be your external WAN IP? This is not possible, if you have a single static IP, we auto assign this to the WAN of the router, if you have a range of static IP's you can use the routers static IP seciton to tell it what the static IP range is for the line and then you can use the router to assign this range to devices on your network.
Markp
0
Kudos
