BT Business VoIP Handsets
Jack155Q4
Member
Hello,
We have just regisered for the BT Business VoIP service. On the back of the router there is the phone line connection which looks like an RJ11. I am told that many phones will work..even normal household handsets? I would need an RJ11 to normal telephone connection adaptor.
Basically I am asking which phones are compatible and where is best to look? We only need something basic.
Many thanks,
Jack
1 ACCEPTED SOLUTION
Accepted Solutions
Tracey
Guru
Hi Jack155Q4
A RJ11/ Voice port doubler is supplied as part of the BT Business Hub and supports a maximum of two business broadband voice lines. (grey connector)
Most standard touch-tone phones work with the Broadband Voice service . You cannot use the older pulse-dial phones or the BT Quartet range.
Hope this is of help
Tracey
BT Forum Moderator
If you like a post please click on the star image on the left-hand side of the post.
If someone answers your question correctly please let other Forum members know by clicking on Accept as Solution on the right-hand side of the answer post. Please also consider replying to the post stating that your question has been answered successfully.
View solution in original post
1 REPLY 1
Tracey
Guru
Hi Jack155Q4
Tracey
BT Forum Moderator
