BT Hub 5 85TG
gazy007
Member
Hi,
Could please someone direct me as how to setup port forwarding on the above HUB and lock the source IP address down for port forwarding? I want to allow two IP address to our monitoring system from outside and I cannot find anything where I could allow that?
Thanks,
2 REPLIES 2
spank
Grand Guru
Hi there,
First you need the No Nat multi IP added to your account.  This will give you 5 no nat addresses to use that you need to assign to the devices within your network.
Once you have the addresses you will be able to set up the hub 5 in the 'static IP' menu.
You will then need to set up port forwarding to pass the traffic to the devices.
markp
Grand Guru
Hi gazy007,
I realise you posted this a while ago and hoping you’ve already found the answer you needed, but just in case and for other members who might have, with the Hub 5 you can get port forwarding setup guide here.
As for the BT hub/router only allowing certain IP's through, they do have have this cpapability, you would need to look at replacing it with a different hub/router if you want this functionality.
Regards
Markp
