BT Infinity Modem Status
danielshaw007
Member
Hi there, I have just had BT Infinity installed today and is working great! Line sync at 40mb down and 10mb up! (according to the engineers handset!)
With the old bt hub i was able to see the sync status of the modem, the downstream and upstream.
Since the Infinity system uses a sererate router and modem.. is it possible to login to the modem to check the sync status or can the sync status be displayed from the infinity hub 2.0?? I cant seem to find it anywhere.
3 REPLIES 3
Alun
Master User
Hi danielshaw007,
Can I just confirm if this is a Business or Residential connection? BT Infinity is a Residential product.
Regards,
Alun
BT Business Support Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
danielshaw007
Member
Residential, its just been installed at my home!
Sorry for confusion as this is the business forum after all!
Alun
Master User
No problem. You would be best to perhaps place a post on the Residential Forum as they would be best placed to assist with this. Hope this helps.
Regards,
Alun
