Hi Forum,
Just setup a BT Inspiration system I acquired from an old office clearence. We have two analogue lines running in, and four extensions off the system. Works great.
I would like to setup the system so that if line 1 rings, only extension 20 and 21 ring. And if Line 2 rings, only extensions 22 and 23 ring. I am sure its easy to do...
Is it also possible to ensure that extension 20 and 21 can only make outgoing calls via Line 1, and extensions 22 and 23 via Line2?
Thanks in advance.
Or, let me know if these requirements are not possible....!
I hope it is possible as I am also thinking how it should be done. I have a plan of doing this next week and I really need a lot of help.
______________
Business is the game!!
Hi, not had much experience on Inspiration but tha manual can be found here http://btbusiness.custhelp.com/app/answers/detail/a_id/16105/~/bt-inspiration-installation-%26-maint...
