McAfee tells me I need to reinstall my BT PC security - how do I do this please?
I tried on line help and went from 20 in the queue to 1 then was told there was no one to help so my request was cancelled !!!
I tried the email reply only to find the link did not work!!!
Help please ![]()
Solved! Go to Solution.
Hi Will,
Im afraid this is not something that we can assist you with here.
You would need to speak with our technical support team will be able to assist (0845 600 7020 opt 2).
Hope this is of help.
Tracey
BT Forum Moderator
Now McAfee security center is telling me my subscription has expired and when I try to renew [why should I'd need to when it is part of my BT package?] I get a BT error page !!!!!!
Help please!
Hi Will,
Sorry to read about the problems you are having with the BT PC Security pack.
Have you had a look at our Help and Support section BT PC Security?
Thanks in advance
Tracey
BT Forum Moderator
Yes! I phoned the help no. and was told to remove the existing McAfee security I had on my PC and then reinstall it. Unfortunately the download from McAfee is not working. When I accept the conditions and press to download I keep getting "Oops! ...... could not connect" message 😞
My PC currently has no protection!!!
Hi Will,
Tracey
BT Forum Moderator
Great support from the BT tech' help - all sorted now & bugs removed ![]()
Ooooops - THANKS!
