Problems with BT2700HGV wifi
Artmachine
Member
Just received a brand new BT2700HGV Business Hub and we are having terrible problems with wifi reception - any machine more than 10 feet away from the hub (we use both Macs and PCs) continually loses the connection with the hub and needs to be logged off and logged on again before it will reconnect. We know the problem isn't with the layout of the place since we were previously using an old BT Home Hub for wifi which perfectly OK at the very end of the building.
1 ACCEPTED SOLUTION
Accepted Solutions
alastair
Grand Guru
change the wifi channel in the hub from auto to 6 or 7
=~~= All Glory to the Hypnotoad! =~~=
View solution in original post
2 REPLIES 2
alastair
Grand Guru
Artmachine
Member
Many thanks, Alastair, that did the trick!
