BT V-IP / BT Broandband Module Plus with existing Router
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
We have recently purchased a BT Broandband Module Plus along with V-IP feature phones for the BT Versatility phone system. Our current setup is using the BT 2700HGV 2wire router to access the internet. Is it possible to use the BT Broandband Module Plus VOIPs capabilties whilst retaining the 2wire router? I've had a good read through the user manual and wish to disable the ADSL connection of the BT Broandband Module Plus. I've looked into the ETH/DMZ setting on the broadband module however no matter what settings I change it does not seem to get an internet connection. Your thoughts/ideas would be most appreciated.
Current set up is as follows:
Internet
BT 2700HGV Router
172.16.0.1 / 255.255.0.0
172.16.0.2 / 255.255.0.0
Server
192.168.1.85 / 255.255.255.0
PC1------------------------Switch----------------------------PC4
192.168.1.50 / \ 192.168.1.51
PC2 PC3
192.168.1.52 192.168.1.53
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi,
I've spoken to the Versatility tech team and have been advised that this is possible. You will need to configure the DMZport on the Business Hub. A guide will be uploaded to the Support FAQs - I will update you here when it has gone live.
If you require further assistance you can call the BTV Customer adviceline on 08702 408 377.
Minicheddar
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
I have connected by Versatility with a Broadband + module via a cable router, rather than ADSL and can confirm it will work.
I have also managed to configure IP trunks that use another SIP provider (bypassing the advanced settings restriction).
The system will operate fine.
Dave
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
We note that you stated that a guide would be provided in Support FAQ, and that you would provide
an update in the forum.
Since eleven months have elapsed, please could you advise when this may occur?
We would also be interested to see further guidance in relation to configuration of the Broadband Plus
module without another modem or router, for remote V-IP phone operation with BT static IP addresses.
Thank you.
Watching out for innocent lambs being led to the ** slaughter.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
In regards to the previous posts, it is possible. You would need to connect an Ethernet cable between a LAN port on the BT 2700HGV Router and the ETH/DMZ port on the BT Versatility (BTV) Broadband Module + (BBM+). You would then need to configure the ETH / DMZ port on the BTV BBM+ to be an IP Gateway and select the required network settings appropriate to your network. Once this is done there should be internet access on the LAN of the BBM + and the VoIP can be programmed up as usual. It should be noted that if there any firewalls on your network they would usually need to be configured to forward the VoIP traffic to the BBM+.
With regards to guides for this, they are available to customers that have a BT maintenance contract via the product support website. BT maintained customers should register on www.productsupport.bt.com to access these. Customers without a BT maintenance contract would need to contact their system maintainer.
Kind Regards
BT Business Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I've been trying to set up our BBM+ via a cable modem aswell, but alas without success.
Have set up VOIP Featurephones connected to the BBM+ LAN and on that LAN they work fine, but the problem is trying to get them connected from outside via the WAN.
We have a cable modem with an IP address of (example) 60.30.401.501
This modem is then connected to a D-Link router with a gateway address of (actual) 192.168.0.1, which then connects to the whole of our internal LAN.
On the BBM+ module, have set it up as a LAN gateway using the address 192.168.0.50 to fit in with the IP range of our internal LAN and the D-Link Router.
Have set up the ETH/DMZ port with the cable modem IP address 60.30.401.501
On the D-Link Router have opened up UDP ports 5060-6000, and TCP port 5566.
Like I said, if I setup the VOIP featurephones with a remote setting of 192.168.0.50 (the BBM+ address) and connect them to the BBM+ LAN they work fine.
However, if I set them with a remote setting of the cable modem - 60.30.401.501 they can't find the appropriate destination and won't connect.
Can someone help please?! Have I put the correct modem settings in for the ETH/DMZ port? Am I using the correct remote setting on the VOIP phones by using the cable modem address of 60.30.401.501? Have I set the LAN gateway of the BBM+ properly by using a LAN address within our D-Link Router IP Range?
Have worked in IT for over 20 years, but this is REALLY doing my nut in!!!!!
Can anyone help please? I'll be EXTREMELY grateful!!! 🙂
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
i know its a bit old, but dod you resolve this?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Dave, You mentioned that you have managed to set-up non-BT IP trunks on your BB module. I am trying to do the same, but cant manage to get it to connect. Any help would be very much appreciated. I am actually trying to add a couple of extension lines from an Asterisk to appear on the BTV as SIP Trunks.
Thanks,
Gary
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It seems to be impossible or I maybe just doing it differently. I have tried it a couple of times, but to no avail. I hope anyone could help us on this problem and be able to share it here.
