BT Versatility HELP - Programming Extension Missing !!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Please can someone help - I wanted to move the main featurephone so changed the programming extension, through the programming menu, but when I connected it to its new extension it says programming Refused !!!, I can't connect the phone to another extension as the other extensions won't even power the phone itself. I tried putting it back to the original extension and it still says programming refused !!, I definitely selected the right extension - so now I'm at a loss really and without access to teh programming menu I can't programme the system or make any changes.
Can anyone help ??
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
Try a warm reset (out of hours)
• Phone reset
Remember the simple phone reset code 739, which can be dialled from any extension phone.
• System reset
Reset: To do a warm reset of the BT Versatility press the reset button on the CCU MDF. You may also
choose programming mode and choose system, reset options, and reset.
Mike
BTfix
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
To be sure you need the engineers software on a lap top. This gives you an overview of how the system is programmed.
Google Freeindex to find a local engineer to you.
Regards Colin Ogilvy.
