Hello folks,
I am working on an BT versatility system, have 4x V8 featurephone handsets and 2x CO lines (one of which had an AUX in the past) and everything is working OK, however, the customer has changed from BT to another company for their phone service, in doing so they have lost the aux line of the main number, now they only have one CO line for their main number and a separate line which they use for ADSL broadband (Whic is still with BT on an 2700 router)... Im not sure at this stage if the new company (O2) can supply them with an aux on the main line, however, for the moment is their a way in which I can 'trip' the main line to the broadband line on busy... If i understand correctly, this will not happen automatically since i am not dealing with ISDN or AUX lines... is it possible through the Versatility to set up an auto divert or forward, if as busy tone is recieved on the main line?... i understand this may be a chargeable divert but thats not a problem for the moment.
So just to confirm, normally when you ring the companies main number, you recieve an AA, if you select an option and an employee answers the phone all is well, however, if a second person tries to call the main number, the willl recieve a busy tone...
I have checked over the wiring, and what BT engineers have done is they have setup two NTE5 sockets, on one of them it says the main company number line1, and on the second box they have written the main number with "line2" on it, which i assume was the orignal AUX line, however, upon closer inspection i notice that this box is actually hooked directly to another adject box which is a BB line and is basically not being used for anything except BB, so am i right in assuming they have somehow diverted LINE1 (Which is the main number) to the BB number on busy?... if so, how can i reprogram the system to do this?...
Secondly, The customer is using Auto Attendant at the moment, however, for some reason incoming calls will flash red on line 1 LED but no sound can be heard on the handsets... but on internal calls ringing can be heard, also, if i set the incoming ringing option in the menu to Extension or Group then the phone will ring audibly. Any ideas how to get around this one?....
Many thanks
Adam
