BT Web Hositing Starter Pack
Santorini2000
Member
I purchased a BT Web Hosting Starter Pack £ 2.99 per month
Please could someone advise me on the under-mentioned:-
1.  Define your site
On this page their is a section which says Web Address then      electriciansheffield.com
there is a box next to this what do I insert into this box
2. I have chosen a multi page site
I then go to " Customise "
When I reach this page it has a choice for " Link Opens in "
a) Default Frame
b) Entire Window
c) New Window
What option do I choose
3. When I am designing my website do I need to press the " publish " button every time I design a new page
I used to do this and ended up with my pages appearing on the internet with
No Header
No Index down the left hand side
No frame to my webpage
I really would appreciate if someone can advise me where I am going wrong
1 REPLY 1
Pete
Member
HI Santorini
I am in the same boat as you.
Do not Publish your site untill you have done all that is needed. If you need to check how your website looks save all that you do each time you alter a page, To check it click on PREVIEW to see how it looks. Sorry that I cannot help anymore.
