BT email address
rdg1972
Member
Hi,
Is the [email protected] email address still active?
I need some lines cancelled and also 1 moved and would rather email the information through.
Regards
R. Godden
3 REPLIES 3
markp
Grand Guru
 Hi  rdg1972,
If you would like to cancel services via email, if you go to contact us, you will see a section for closing your account, click this, then click email.  Hope this helps
Regards
markp
rdg1972
Member
Thanks but thats not really much help. I don't want a email form to fill in but the email address itself.
I also don't want to close an entire account.
markp
Grand Guru
Hi rdg1972,
The only way to cancel products/lines, is through out customer options team, which is the link I have given you, unfortunately we have no direct email address for them
Regards
Markp
