BT versatility help needed
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hello everyone
Im new to the forum and need help deperately.
I checked a versatility system for a person and as the system was showing no activity at all i recommended they buy a second hand system and i would install it for them.
ISDN lines were checked (by BT onsite) and i installed the system but i just cant get the system to let me dial out as it just shows busy with each try on each line.
Done resets and changed modules and it just wont work.
Do you think thr switch is faulty or is there something i am missing?
Also the switch is showing activity now.
Any help would be appreciated.
0
Kudos
1 REPLY 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
When you change the modules make sure the system is disconnected from the mains and the battery is disconnected. It should then see the modules on power up.
0
Kudos
