Hi,
After two days i finally have access to the Admin Page! Selected a template, which was stated to be "fully customisable", so now :
1. how do i change the background colour?
2. Remove the picture in the header? (not my logo, but the picture that comes with the template)
Solved! Go to Solution.
Found it....Under Advanced Design it allows me to Align the Header Box content and change/remove background colour....
Hi
Which program are you using to create the website?
Don't know!
Which ever one comes with eShop....(not elite - just standard eShop) Is it easy site wizard pro or something?
