Url in Blog
jules
Member
Hi
I have set up a new blog using the BT Website Center but when I type out the full url link
it will not work
can anyone tell what i am doing wrong
thanks
3 REPLIES 3
Chantale
Master User
Hi Jules
Could you provide me with the domain name?
jules
Member
Hi
www.apartments2book.com
Fiona
Grand Guru
Hi
It looks like your Blog has been created with the older version off EasyBlogBuilder Application. You could try upgrading to the newer version and then entering the Blog and URL.
If you continue to have problems with the newer version, please get back in touch with details of the steps you are taking and any errors or issues you encounter.
Kind Regards
Fiona
BT Business Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
