Blocking external calls to one extension
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I can't work out how to block external calls to one of our extension numbers (but still recieve internal calls, so the 'do not disturb' thingy isn't any good), have a system x feature line with hunt group, any help would be great.
Cheers, Jaq
2 REPLIES 2
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Jaq,
Have a look at at this list of Multi Line Hunt Groups FAQs, I think the Adding and removing MLHG lines or the Determining MLHG call distribution section may be what you are looking for, let me know!
Cheers,
Steph
BT Forum Moderator
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
If you are in a huntgroup and activate "Huntgroup do not disturb" you then cannot dial that extension internally.
However as you are off a System X exchange they can call the extension by dialing the Bypass number of that line.
(This will be a chargeable call). Hope this helps Andy
