Solved! Go to Solution.
Hi there,
Some URLs can be made as virtual directories.
Regards
Andy
BT Forum ModeratorAndy,
Thank you for the clarification.
I have set this up with other hosting companies, but I cannot find any ASP or IIS settings on the BT control panel.
Where can I select that the public fold should be run as an 'ASP Application'?
How do I allow ASPNET write permissions on the App_Data folder?
Blogenegine.net is a true ASP.NET 2.0 application and is one of the kits promoted by ASP.NET, is there a reason you cannot guarantee it will function correctly?
Thanks again Andy,
Hi Tonye2044,
Can you please supply your domain name?
Tracey
BT Forum Moderator
i think BT cant say it will always work is because since its third party if their software/servers/etc go wrong its not BTs fault so you'd need to speak to the third party if it goes wrong.
BT provides the space for it to run and the services needed but thats all
