Bt Business hub - Failure
stevie09
Member
Hi can anyone help. today my hub switched off and then rebooted.
now it power's up, switches on the wifi, then powers off.
How can I restore the firmware manually?
1 REPLY 1
JohnE
Guru
Stevie09, there is a hardware re-set button on the rear of the Hub, near the power socket.  It's recessed, so you will have to use a bent paperclip or similar in order to operate it.  It needs to be held in until the power light goes out and then the router will re-start, self test etc.  It does return the Hub to it's factory settings and you will need to re-enter your broadband login details, along with any other configuration you have set up yourself.
If you have any difficulty with this, contact the hlepdesk on: 0845 600 7020 Option 2.
