Buisness Hub 3 & BT2700hgv
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
All,
I am looking to extend the wireless range of the BH3 and was wanting to use an old 2wire BT2700hgv. Can this be done? If so how should I configure the routers?
Many thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
My remote 2700s acting as WAPs, do NOT appear on the master 2700s list of devices either. That may be because of one of two reasons - firstly outside the allocatable DHCP range, but probably not as I have other devices with fixed addresses and they appear, the second reason may be because it is a switch/part of the network rather than a terminal device - mg Gigabit switches do not appear either.
However, I can access each WAPs interface from anywhere; including via a second WAP.
The main reason I suggest an IP address outside the DHCP range is to ensure there is no clash - if it is in te range and turned off, another device could be allocated the address and when the 2700 is turned on it will cause an address clash.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@MHC
You are right about that I am sure & it is wise to allocate an address to the AP that the router can not issue to some thing else, I will do that in future
I have noticed though having run a 2701 at a pub for eighteen months that it never ever issues the same address to another device once a device has already been issued with it. I have about 150 devices coming & going there & they always get the same address.
I guess though if it ever ran out of addresses it would start to re-issue
Rob
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Rob
They will get the same address if te DHCP lease has not expired - if you really did monitor closely you might find that once te DHCP lease expires (which for regulars may never happen) then a new device could be allocated that IP address.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@MHC
It is because I have to monitor this so closely that I have noticed this, There are only 15 devices in the device list this morning out of 153 registered & 7 of them live on-site. The lease time is set to default I visited site yesterday my windows, Mac & android device all got their regular addresses allocated I have not been in there for over a month. I keep a copy of every device details in a word document showing Device name, Mac address IP address, content screening group & owners full name. the IP addresses never changes. What you say makes perfect sense but it does not work like that for some reason. All logs checked morning & night
There are 5 regulars with devices that can't go 24 hours without going in the pub so you are right there too
I have another site with 4 computers on a BH3 all DHCP all use VNC to each other by IP address shared folders, printers etc IP addresses never change there either, even after their 2 week summer shut down. They have run like this for 4 years or more originally on a 2700 they have never had a problem
Rob
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
whiller123
Rob
The BT hubs will always re issue the same IP address to a device unless that IP address is unavailable despite the expiration of the lease. The exception to this is if all available addresses have been taken when connecting a new device it will then re-cycle expired lease addresses.
PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Engineer
Hi Dave
Got your private message & replied,
Today I am being thick! I thought when you signed your previous post PM you were maybe David Cameron, its my age you know!
Yea it appears right about the addresses I find exactly that. What MHC says though about the lease makes perfect sense, I have looked at some of his (or her) other posts & he is always spot on the numbers. I may restrict the number of available addresses to test the theory!
Ah no life is to short! if it works it works. Lets move on!
Rob
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@whiller123 wrote:
... What MHC says though about the lease makes perfect sense, I have looked at some of his (or her) other posts & he is always spot on the numbers.
I'm a he ...
Playing around one day, I managed to a master 2700 connected vioa Ethernet to 4 further devices. Then one of those to four more and one of those to a variety of Thmson, 2wire, Netgear and DLink devices all running as WAPs.
It is just a case of making sure the addresses are correct and in the right block.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@MHC
Sorry trying to be politically correct & not sexist Your point is noted with dignity.
I am fairly inexperienced with the 2wire but have noticed some quirks. & am learning fast, never to old to learn & **bleep** I have some learning to do. You seem very knowledgeable about this stuff & I note all you posts with interest
Hope my posts did not offend as this is not my intention I just wish to share what I have learned.
Rob
For the record the word that the system has shown as **bleep** was nothing more than a big wall that holds back water!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Not offended and I know why you put it there ...
There is a good resource for the 2700 at:
http://bt2700hgv.tripod.com/ir1002700HGV.htm
Some relevant, some not, but it tells the story from start to finish.
There are quite a few bits of info there that originated from me.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@MHC
That is OK then
There is interesting stuff on there I have been there before when I needed to use the Hub with a different ISP
Rob
