Business broadband option 2
voclahokor
Member
I have had this service for a while now, but no bt hub was ever delivered and I have been using my own.  I now need to replace my router. How do I get a BT business Hub or Voyager modem?
3 REPLIES 3
Plumly
Grand Master
Hi Voclahokor,
you can contact the support team who will be able to send you one, they might try and charge you though depending on your package,
I was told they are £79 when i tried to get one,
Plumly
MHC
Guru
Depends on whether you package was a "with free Hub" or not.
If you want a BT 2wire2700HGV - either buy from BT at £59 or £79 or from ebay at £5 to £10 (new).
danhague
Power User
Hi voclahokor. It's best if you can contact the support team so they could give you options.
