Can't find server btopenzone but connect to the network , any help ?
vektar
Member
Hi,
my imac shows its connected to BTWifi with FON but I can't get https://www.btopenzone.com:8443/home to open in my internet browsers , tried Safari , Firefox , and chrome and nothing works , still can't find server , and btw it was working perfectly a few days ago and then stopped working .
Any help ?
V.
2 REPLIES 2
Plumly
Grand Master
Best guess would be that the device that has BTWifi Enabled is currently experiancing a connection/Throughpout issue,
markp
Grand Guru
Hi vektar,
If you go to the BT WiFi website you will be able to get help and support for this.
Regards
markp
