Change of design.
lozuk
Member
Hello
I bought the BT web consult and build package and the site has been up and running with very few problems. I've now decided that I no longer like it and would prefer another design. I've been shown how to use the easy site wizard so was wondering if I am able to design another site using the templates or do I have to stick with the one I have now.
2 REPLIES 2
Rarr
Member
Hi Lozuk,
The choice of content on your webspace if completely up to you 🙂  MIght be worth saving the files from the consult and build site just in case you have decide to revert back though.
The easy site software has a lot of pre-built layouts available, there should be plenty of choice for you to find something that suits you.
Hope this helps
lozuk
Member
Fantastic. Thank you for your help.
