Changing DHCP Network Range
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I used to have a NetGear hub which used the network 192.168.0.x
I have a BT Business hub which is using network 192.168.1.x but still have two printers which have hard coded ip addresses of 192.168.0.60 and 192.168.0.107 which I now can't connect to. These printers are hired and I haven't got the authority to change the network addresses. Though I am about to seek the suppliers advice.
if I log on to the BT business hub then follow
Settings -> Lan -> Private Network
the hub has these settings where the DHCP Server Enabled CheckBox is ticked.
DHCP Server Enabled
DHCP Network Range
- 192.168.1.0 / 255.255.255.0 (default)
- 172.16.0.0 / 255.255.0.0
- 10.0.0.0 / 255.255.0.0
- Configure manually
How can I change my Business hub so that it can see the two networked printers.
I've tried to configure it manually which it seems to accept but then the network drops and I cannot then connect to the internet, the hub let alone the printers. I then have to rest the buiness hub to get the internet back. Therefor back to where I started from.
How do I proceed?
The textboxes for manual configuration are -
Router Address:
Subnet Mask:
First DHCP Address:
Last DHCP Address:
If I follow -
Settings -> Lan -> NAT & Address Allocation
I see that it's configured to allocate addresses from the Private from pool: 192.168.1.0
I've not changed this at all.
Alex
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Well, I've managed to now connect the two network printers by changing their hard coded ip addresses.
It would still be nice to know how to re-configure the router. Not a pressing issue now.
