Changing Wireless network/SSID name
AliceCC
Member
I would like to know how to change my wireless network/SSID name on the BT hub 3.0?
I have tried to follow the instructions given on the BT business website but all this allows me to do is change the wireless key/password...
Any help much appreciated.
1 REPLY 1
LinuxLady
Member
Hi,
You need to click on the "Advanced Settings" option in the menu bar. That way, when you go into the wireless settings you'll have a sensible amount of options - including your SSID 🙂
TTFN
Faye
