'm not hugely experienced with Cisco routers but I've managed to configure a Cisco 2921 with BT Infinity which works fine. I can access the web/browse etc.
The only thing I'm struggerling with, is my BT package has static IPs currently the BT Home hub dials with PPPOE and the static IPs on the hub appear to be a virtual interface. Does anyone know how to configure this similar style setup on a Cisco router?
Conf below;
Current configuration : 3570 bytes ! ! Last configuration change at 11:27:34 UTC Sun Apr 8 2018 by mroot ! NVRAM config last updated at 11:17:34 UTC Sun Apr 8 2018 by mroot ! NVRAM config last updated at 11:17:34 UTC Sun Apr 8 2018 by mroot version 15.1 service tcp-keepalives-in service tcp-keepalives-out service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname router ! boot-start-marker boot-end-marker ! ! no logging console enable secret 4 bKeS4xiYXaJxSPFOy2jnfzOvVRFm80AdocXk.8g4BYE ! no aaa new-model memory-size iomem 25 no ipv6 cef ip source-route ip cef ! ! ! ! ! ip domain name domain.com ip name-server 8.8.8.8 ip name-server 8.8.4.4 multilink bundle-name authenticated ! crypto pki token default removal timeout 0 ! ! license udi pid CISCO1921/K9 sn FCZ170595H6 ! ! username mroot privilege 15 secret 4 mOA83nec.Q62OjRrUlRfSx3EZxHay2wbwsJ8jRpOd5c ! ! ip ssh version 2 ! ! ! ! interface Embedded-Service-Engine0/0 no ip address shutdown ! interface GigabitEthernet0/0 no ip address no ip route-cache ip tcp adjust-mss 1452 duplex auto speed auto pppoe enable group global pppoe-client dial-pool-number 1 ! interface GigabitEthernet0/0.1 encapsulation dot1Q 101 ip virtual-reassembly in no ip route-cache pppoe enable group global pppoe-client dial-pool-number 1 ! interface GigabitEthernet0/1 ip address 10.1.10.50 255.255.255.0 ip nat inside ip virtual-reassembly in ip tcp adjust-mss 1350 duplex auto speed auto ! interface Dialer1 ip address negotiated ip access-group 101 in no ip unreachables ip mtu 1492 ip nat outside ip virtual-reassembly in encapsulation ppp dialer pool 1 ppp chap hostname [email protected] ppp chap password 7 14071E1E01063F38302D2164 ppp pap sent-username [email protected] password 7 044B07130223595D1D1C1746 ! ip forward-protocol nd ! no ip http server no ip http secure-server ! ip nat inside source list 1 interface Dialer1 overload ip route 0.0.0.0 0.0.0.0 Dialer1 ip route 10.1.0.0 255.255.0.0 GigabitEthernet0/1 ! access-list 1 remark INTERNET-ACCESS access-list 1 permit 10.1.0.0 0.0.255.255 access-list 101 deny ip 192.168.0.0 0.0.255.255 any access-list 101 deny ip 172.16.0.0 0.15.255.255 any access-list 101 deny ip 10.0.0.0 0.255.255.255 any access-list 101 deny ip 127.0.0.0 0.255.255.255 any access-list 101 deny ip 255.0.0.0 0.255.255.255 any access-list 101 deny ip 224.0.0.0 7.255.255.255 any access-list 101 deny ip host 0.0.0.0 any access-list 101 deny ip host 255.255.255.255 any access-list 101 deny udp any any range 33400 34400 access-list 101 permit icmp any any net-unreachable access-list 101 permit icmp any any host-unreachable access-list 101 permit icmp any any port-unreachable access-list 101 permit icmp any any packet-too-big access-list 101 permit icmp any any administratively-prohibited access-list 101 permit icmp any any source-quench access-list 101 permit icmp any any echo-reply access-list 101 permit tcp any any established access-list 101 permit udp any any ! ! ! control-plane ! ! ! line con 0 logging synchronous login local line aux 0 logging synchronous login local line 2 no activation-character no exec transport preferred none transport input all transport output pad telnet rlogin lapb-ta mop udptn v120 ssh stopbits 1 line vty 0 4 logging synchronous login local transport input ssh line vty 5 1370 logging synchronous login local transport input ssh ! scheduler allocate 20000 1000 end
